This boat is perfect for a large family, corporate entertaining or even two families. It is truly one of a kind. It’s exceptional because the living space is very roomy with stand-up cuddies and a lot of sleeping space for friends and family
This boat was removed from the lake to be completely restored properly by Star Houseboat Renovations in Monticello. This boat has it all including bow and stern thrusters and a backup camera. You really need to see this boat to appreciate the perfect condition it is in.
This boat is ready to go 10 years with no major maintenance or repairs, just normal upkeep.
For sale by owner 859-338-9513 located at Grider Hill Marina, Albany, Kentucky
Accommodations
• 7 bedrooms –1- King master B/R, 1-king stand up cuddy, 2-queen stand-up cuddies, 3- queen cuddies all brand new mattresses, large bedrooms
• 2 full baths 1-off mater B/R with tub, 1 - hall way with shower, 2-sinks in lower cuddies
• Salon – large and roomy also side door by steering wheel for easy viewing of back/side of boat and access to outside stairs
• New back up camera
• New couch and coffee table and end tables
• All new mattresses
• New flooring in main areas and baths to accent new granite, new carpet in cuddies
• New ceiling throughout
• New LED lights throughout, many on dimmers
• New rope lighting in salon and master bedroom
• New brushed nickel sink and shower faucets, new brushed nickel drawer pulls and bathroom accessories.
• New granite in both bathrooms, master B/R, cuddies, kitchen, and salon area
• Stack washer and dryer
• TECMA Heads
• New 3.5 ton heat pump HVAC system 15 seer with 10 year warranty starting 7/2019
• Bow and stern thrusters
• Two 20 gal hot water heaters
Galley
• New granite countertops
• All new Whirlpool appliances with 1 year warranty until 7/2020
• New smooth top convection oven
• New refrigerator with bottom freezer and ice maker
• Separate ice maker
• New microwave
• New dishwasher very quiet
• New LED lights
• New facet and sink
• New backsplash
• Several cut glass cabinet doors with cabinet lighting
Entertainment
• Entertainment center completely remodeled
• New 60” Samsung flat screen TV 1 year warranty until 7/2020
• New Denon Receiver with two zones- play music outside and master B/R while watching TV in Salon 1 year warranty until 7/2020
• Bose surround sound in salon on main zone
• 10 addition new speakers on zone two with separate volume controls 4-on party top, 2-front deck, 2-back deck, 2-master B/R
Top Deck features
• New Pitthane roof installed and 30 foot of gutter board replaced Note- fly bridge, bar and all railings were removed all holes patched before new Pitthane put on. It was done right.
• Fly bridge, bar and slide repainted, they all look brand new
• New canvas on sides
• New granite and faucet on bar
• New LED dimmable rope lighting on party top
• New refrigerator in bar
• New speakers with volume controls
• All driving controls on fly bridge work great and new USB charging station installed
Additional outside updates
• New outdoor carpet on entire boat and outside steps
• New canvas
• Two walls replaced and painted to match, no moisture in any walls
• New rub rail on 90% of boat
• New vinyl soffit with LED lights and new fans front and back decks
• New Grill
• All windows, doors, cabin trim cleaned and sealed
• New rear locker doors and handles with locking keys
• Entire boat was detailed including fine cut compound and good coat of wax
Electrical
• Two 50 AMP shore powers
• New inverter panel with 8 new batteries
• New LED lights throughout boat
• New LED rope lights in salon and master bedroom
• New LED rope light on party top
• Many dimmable switches throughout boat
• 2 – 20 gal water heaters
• CO2 detectors throughout boat
• New 3.5 ton HVAC heat pump 15 seer with 10 year warranty starting 7/2019
Tanks
• Fuel tanks 3 @ 95 gallon = 285 gallons
• Fresh water tanks 3@ 80 gallon = 240 gallons
• Waste holding tanks 2@ 80 gallon = 160 gallons
Engines and Mechanical
• Twin V- 8 MerCruiser Engines with Bravo II outdrives
Note the following service was just completed 8/2019:
- Out drives replaced gimbal bearing, u-joint bellows, exhaust bellows, shift cable bellows, short shift cables, anodes, gear lube and checked engine alignment
- Engines completely serviced with oil change / filter, fuel water separator, new impeller, plugs, wires, rotor and cap.
- New Composite transom blocks and new port transom assembly
• 20 KW Westerbeke generator completely serviced and repaired – it has just had a new water pump, fresh oil change, fuel water separator, plugs, wires, rotor and cap.
• PWC fueling station – has new pump
• Bow and stern thrusters- stern thruster just rebuilt with 1 year warranty, also new thruster controls
2019 Sumerset 18' x 88' $395,000
- 266412_20191007080340277_0_LARGE.jpg (60.25 KiB) Viewed 5347 times
