Sharp HB roof repair and gel coat
A forum for you to ask and answer any Boat related technical question
Pop-O
Post by Pop-O »
Work is finished on my boat. :) :) :) The back corners had to be replaced due to bad design by Sharp. A lot of their boats either have or will have this problem. Gel coat also done by the same crew that fixed the corners. They all worked for Sharp until they closed. Did a great job with minimal mess. Larry Blevins did the work. He is working on another boat beside mine now and has done several others here at SD.
Re: Sharp HB roof repair and gel coat
makes you wonder did they mess up the designed for job security later lol
Pop-O
Post by Pop-O »
Likely not. Sharp went into bankruptcy and is out of business. Maybe didn't want to deal with close to 500 upset boat owners!
It's my understanding that Sharpe went down due more to marital and divorce issues....
Pop-O
Post by Pop-O »
Heard that also. From where I sit, I like my reason better - class action suit from several 100 boat owners or 1 mad lady???
Return to “Boater Tech Swap”
