fuel efficiency
A forum for you to ask and answer any Boat related technical question
fuel efficiency
Heres the situation my friends....1994 chris craft 21 foot concept cuddy.carbureted 302 high output.In my quest for lesser fuel consumption I have updated the electronic ignition and a complete tune up....plug gaps set per electronic ignition companys specs...and valves checked for lash...I noticed the spark arrestor was only 6 inches wide and 2 inches thick,seemed a lil restrictive to me. So the questions are....carbureted or fuel injected? Would a taller and wider arrestor help out? And prop....is there a formula to figure out prop size?
Re: fuel efficiency
depends on what you are doing.
If you don't mind taking a little while to get on plane and don't need to rev out maybe a more agressive prop to cruise along with?
I know when I went from aluminium to stainless prop and changed the pitch just slightly more agressive I got better fuel economy on my 305 Carb merc in my 21' Cuddy I had..
I think we need pics. not cause it would help you but just cause I love seeing boats especially when it is one of someone I kinda know. lol
Re: fuel efficiency
E_HILLMAN wrote:depends on what you are doing.
Just cruising down the lake...no tubes no skis....right now I can run at 40 mph at about 3500 rpm. Id like to keep the speed but lower the rpms...obviously changing the prop would be a start. At the moment planning is not an issue....she will jump up on plane quickly...
Re: fuel efficiency
Hopefully someone with much more experience than me will respond as well..
Return to “Boater Tech Swap”
