If you have Verizon you may need to call the number in this PDF and make sure you opt out of allowing them to share your info.
See attached PDF for more info and you might want to pass on to your friends/family as well.
Verizon CPNI (Customer Proprietary Network Info)
- GetDocument.pdf
- (217.88 KiB) Downloaded 193 times
