I'm with Jpatton looking at moving LakeCumberlandBoaters.com from Yahoo to Bluehost. Going to lock the forum where no posts can be done etc.
If things go well soon we should be on BlueHost instead of yahoo. They are one of the highest rated hosts for PHPBB forums.
Wish us luck!
SITE BEING LOCKED FOR MAINTENANCE
Moderator: E_
Re: SITE BEING LOCKED FOR MAINTENANCE
If you are reading this 3-30-2011 you have found us at our temp address http://lakecumberlandboaters.erichillman.net/forum
As you can see this site is not lock but it is still very much under construction. You may experience login issues as the cookies are pointing back to the yahoo site at the moment from what I can tell but once the domains get transferred properly all should get better.
Thanks
Hillman
Thanks
Hillman
One thing I found that may help with login issues is to delete the board cookies using the link that appears before you log in...
http://lakecumberlandboaters.erichillma ... te_cookies
This link above may not work but there is one on the page before you get logged in...
- jpatton
- Marina/Ramp: Whatever ramp E_HILLMAN decides to put in at...LOL
Just a quick update. Everything has been moved over for a couple days now. We are just waiting on Yahoo to release the domain so it can be transferred to BlueHost. Once that happens we'll be able to use lakecumberlandboaters.com to access the forum.
Ok JP, looks like you can work your magic now
__________________________________________
DOMAIN LAKECUMBERLANDBOATERS.COM TRANSFER SUCCESS
Sunday, April 3, 2011 11:03 AM
From: "support@bluehost.com" <support@bluehost.com>
To: E_HILLMAN
Congratulations! Your request to transfer the domain name
lakecumberlandboaters.com has been completed.
You can now modify your domain contact information and nameserver
settings through your Domain Manager here at BlueHost.Com.
Thank you,
BlueHost.Com Support
http://www.bluehost.com
_______________________________________________________
To: E_HILLMAN
Thank you,
Everyone, it appears the proper name for the site now works. Going to LakeCumberlandboaters.com now should work to get you here.
- jpatton
And we are now live!
- FasterThanYou
- Marina/Ramp: Woodson Bend
GOOD JOB GUYS!!!!!!!!!!!!
THANKS MUCH!!!!!!!!!!!
- jpatton
Thx Faster. We shouldn't see any problems with the new host.
