S.H.I.T.
Have fun with some jokes. Just make sure they are not racist, topless, or too offensive. As you can see we are pretty liberal on what is allowed just don't get offended if you push the envelope and something gets deleted. ;-)
S.H.I.T.
Manure: In the 16th and 17th centuries, everything had to be transported by
ship and it was also before commercial fertilizer's invention, so large
shipments of manure were common.
It was shipped dry, because in dry form it weighed a lot less than when wet,
but once water (at sea) hit it, it not only became heavier, but the process
of fermentation began again, of which a by product is methane gas.
As the stuff was stored below decks in bundles you can see what could (and
did) happen.
Methane began to build up below decks and the first time someone came below
at night with a lantern, BOOOOM!
Several ships were destroyed in this manner before it was determined just
what was happening.
After that, the bundles of manure were always stamped with the term
' Ship High In Transit ' on them, which meant for the sailors to stow it
high enough off the lower decks so that any water that came into the hold
would not touch this volatile cargo and start the production of methane.
Thus evolved the term ' S.H.I.T ', (Ship High In Transit) which has come
down through the centuries and is in use to this very day.
You probably did not know the true history of this word.
Neither did I. I had always thought it was a bowling term.
Re: S.H.I.T.
Its said you learn something everyday. I think I did today.
Hijack; why cant you say s.h.i.t. on tv but the GD is ok?
Return to “Jokes and other hooey fooey”
