Home remedies
Have fun with some jokes. Just make sure they are not racist, topless, or too offensive. As you can see we are pretty liberal on what is allowed just don't get offended if you push the envelope and something gets deleted. ;-)
Home remedies
SIMPLE HOME REMEDIES:
Avoid cutting yourself when slicing vegetables by getting someone else to
hold them while you chop.
Avoid arguments with the Mrs. about putting the toilet seat back down by
using the sink.
For high blood pressure sufferers: simply cut yourself and bleed for a few
minutes, thus reducing the pressure in your veins. Remember to use a
timer.
A mouse trap, placed on top of your alarm clock, will prevent you from
rolling over and going back to sleep after you hit the snooze button.
If you have a bad cough, take a large dose of laxatives; then you'll be
afraid to cough.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move
and should, use the WD-40. If it shouldn't move and does, use the duct
tape.
Remember: Everyone seems normal until you get to know them.
If you can't fix it with a hammer, you've got an electrical problem.
Daily Thought:
SOME PEOPLE ARE LIKE SLINKIES; NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
Return to “Jokes and other hooey fooey”
