Excercise for RE3
Have fun with some jokes. Just make sure they are not racist, topless, or too offensive. As you can see we are pretty liberal on what is allowed just don't get offended if you push the envelope and something gets deleted. ;-)
Excercise for RE3
EXERCISE FOR PEOPLE OVER 50
Begin by standing on a comfortable surface, where you have plenty of room at each side. With a 5-lb potato sack in each hand, extend your arms straight out from your sides and hold them there as long as you can. Try to reach a full minute, and then relax. Each day you'll find that you can hold this position for just a bit longer.
After a couple of weeks, move up to 10-lb potato sacks. Then try 25-lb potato sacks and then eventually try to get to where you can lift a 50-lb potato sack in each hand and hold your arms straight for more than a full minute. (I'm at this level.)
After you feel confident at that level, put a potato in each sack. :ymapplause:
Re: Excercise for RE3
Here's an exercise for you, Jeffie! Put a sock in it! :ymtongue: :ymtongue:
Well at least he only said you were over 50. =))
E_HILLMAN wrote:Well at least he only said you were over 50. =))
And your point is????? :-w :-w
#-o [-( :ympeace: ^#(^
E_HILLMAN wrote:#-o [-( :ympeace: ^#(^
Chicken chit! :ymdevil:
Return to “Jokes and other hooey fooey”
